RCU Forums - View Single Post - How many RPMs on the ground for a West .50V1 with an 8X10?
Thread
08-05-2006, 10:54 AM
15
combatpigg
My Feedback: (
3
RE: How many RPMs on the ground for a West .50V1 with an 8X10?
Here is a look at the entire fuel system, if you are serious about going fast, and don't care about a throttle, then a fixed venturi is the only way to go. The venturi was made on a lathe, but I used to make them on a drill press, with a chisel or sharpened screwdriver for a cutting tool. The needle valve is from an OS .10 or .15 FSR, it has a fine thread and will control bladder pressure. The bladder is latex tubing, you use a syringe to load it with fuel. Bladder systems are more work and can be a pain, but when everything is working right, they can't be beat
Reply
Like
combatpigg
View Public Profile
Send a private message to combatpigg
Find More Posts by combatpigg
View iTrader Profile
