RCU Forums - View Single Post - PST contact?
Thread: PST contact?
Old 08-08-2006 | 03:18 AM
B777
Default RE: PST contact?
Hi,
Just to fill in on fuel consumption. The J600R will burn about 250ml/min at 163,000 rpm and substantially reduced to below 200ml/min at 155,000 rpm. I fly for 8 minutes with reserve for 2 go-around on 2 liters fuel tank.
Kelly is correct that the internal gas canister is designed for 1-2 starts only. PST canister is machined from solid aluminium for maximium strength against rupture in case of a crash. If you want the canister to hold more gas, just make sure that the internal canister is substantially colder than the filling tank.
Regards,
Kraivuth S.
