RCU Forums - View Single Post - A Good First 3d plane
Old 08-16-2006 | 08:56 AM
  #45
Walt and Sage's Avatar
Walt and Sage
Default RE: A Good First 3d plane
ORIGINAL: Cambo
Good point
That plane seems like the best deal because it is less than half the cost of the mojo arf and comes with a fuel tank, wheels, spinner, ect.
How did it go together?
Did it biuld well?
How does it fly?
I am thinking about a thundertiger tt 46 or os 46 ax.
Wouldn't they be lighter than the 52 4-stroke that they say you can put in it?
The plane would build VERY FAST if I used the Goldenrod type push rods
they included.. I installed carbon fiber tubes and ran their wire through
them ... I am sure the included set up would work, but I am just that way..
From what I have learned on this plane is that the 4 strokes will not fit
without modifying the mount... same with even a OS 40LA
Like I said, the vertical pull out from a hover is just WILD with the Webra 36..
If I was to use a 46 it would be an OS 46ax for sure..
IT FLYs GREAT !!!!!!!!!!!!!!!!!
Put on triple rates for this plane..
It does the 3d moves that I have learned BETTER than and plane
I own...
Let me just say also that I have not flown a Mojo..
From what I have heard , it would be HARD to out fly, 40 size...
The only problem for many is the $190 cost...
The Mojo most likely will be my next profile..
