Old 08-16-2006, 02:04 PM
dirtybird
Default RE: Digital Servo Buzz
JR servos are set up with very tight deadbands. Once the potentiometer gets a bit worn or the gears get a bit loose they will do the flutter you described. Its probably not the cause of the crash though. The flutter will stop once there is a load on the servo as you observed. It could drain the battery quickly.
