RCU Forums - View Single Post - BME 115 is Shipping and Flying
Old 08-17-2006, 12:27 PM
RTK
RTK's Avatar
Default RE: BME 115 is Shipping!!!
The 115 "I feel" was just a progression/refinement of the 110. (a good one too) You do not have to use a fully supported mounting ring, which most people complained about. The case is no longer split which makes it better than the old case style that many others manufacturers use and it has a larger carb which will let it run even better thru out the whole RPM range.
As for the 55, it should be here soon if I had to guess.
When you are depending on other suppliers to deliver the correct parts on time you can run into a few snags now and then.
