RE: Fast/cheep/turns
If you bank 90 degrees and pull full elevator, and it tucks down like you mention. I would suggest adding wing weight to the top wing (right side). Or remove any weight you added to the left wing tip for lateral balance. Start with two quarters taped to wing tip and add or subtract from there.
