RE: 3W 106 sagging
Tank location can also cause this -
lower your tank as low as you can
The pressure head -- relative vertical height PLUS carb setup (regulator pressures ) can and do sometimes cause this
alway do easiest things first -if no canisters are in the way
put the tank on floor of model
