RCU Forums - View Single Post - WALKERA 37
Thread: WALKERA 37
Old 08-30-2006, 11:19 AM
  #550
W37 Cepeda
W37 Cepeda's Avatar
Default RE: WALKERA 37
I had no issues with the bindings. As a matter of fact when I put the head together and install it I was over on the negative, without touching. I
adjusted the linkages accordingly and resolved the problem. For the linkages, I purchased the original Align parts, as you can see the pitch linkages are
shorter than the manfacturers originals by walkera. Maybe that is why yours maybe touching.
W37
ORIGINAL: balance_mind
W37 Cepeda,
when you converted the head to the SE head, are you able to have the full pitch and cyclics movements with no binding?
(Full negative with cyclics movement not touching frame : Full positive with cyclics and washout base barely touches rotor head, flybar control lever ball not touching the washout linkage)
Mine seems to be limited by these slightly with the best adjustment I can do. No EPA to adjust on the walkera radio, so think can only adjust the PIT settings to avoid.
Any suggestions?
