Thanks for the reply
I can still shorten the links to stop both the swashplate and washout base from touching the other parts. But at full pitch, my cyclic's movements were blocked/limited by the washout linkages. What is the length of your washout linkages?
Another I can think off is to file the rotor head shorter (closer to the hex screw)
ORIGINAL: W37 Cepeda
I had no issues with the bindings. As a matter of fact when I put the head together and install it I was over on the negative, without touching. I
adjusted the linkages accordingly and resolved the problem. For the linkages, I purchased the original Align parts, as you can see the pitch linkages are
shorter than the manfacturers originals by walkera. Maybe that is why yours maybe touching.
W37
