RE: prob with programming Eflite esc
Hi The esc needs to be able to see the full throttle end point. You might need to move your end point adjustments. Or either you need to reverse the throttle. But watch how much you change things as too full up and you will not get full cutoff. In some cases you have to be able to answer yes=full and no=cutoff center = next question!
steve
