RE: ESC programming prob for CPP
You may have to go into the endpoints for ch3.when on low stick change the endpoint to where it will arm,when on the hi stick change the endpoint to where it will allow programming.Don't forget that if it wont go into programing you must unplug the batt and reconnect before you will see a change on the hi stick endpoint adj. for programming access.
