RCU Forums - View Single Post - Torn CA Hinge
Old 09-04-2006 | 11:59 PM
raideron's Avatar
raideron
Default RE: Torn CA Hinge
LT-40..... The best bet is to cut the rest of those hinges out, and reslot on either side of
the old hinges.. You could cut out the old hinges but then the slots would most likely be
to big for CA hinges, but the pinned hinges would fit..... CA hinges works good, as long
as they are installed with a slight gap, and enough but not too much CA... It's not that
bad of a job.... Good luck..
