RE: cp vibrations
One of the tricks I read here which has helped me to determine if the wobble is the shaft is to simply take off the blades and then throttle up as you hold the heli. If it's still wobbling, then it's probably the shaft. If not, then it's the blades... If you have a bad shaft and replace it the wobble should be noticably gone without blades.
