RE: cp vibrations
ill do that.
im still going to need to get a new pair of blades anyway....i found out to gard that stunt-hover switch..blades moved and hit sumthin hard, now the tips are busted.darn not much. just a leading edge is chiped, less then 1/4 inch on one, nuthin on the other.
its the shaft that is bent. also, where do you have your gain and perportional set at?
