RCU Forums - View Single Post - tip stalling HELP!
Old 09-14-2006 | 06:20 AM
j.duncker's Avatar
j.duncker
Default RE: tip stalling HELP!
Assuming you have tip ailerons you can set them up 3-5 mm this gives washout.
If you have strip ailerons you can replace them with some that you carve from scratch so that they twist UP towards the tip.
Both will reduce the tendancy to tip stall.
