RE: Eletronic engine syncronizer **SUPPORT **
Jim,
Please re-desribe the problem you are seeing now. Initially you described some of the symptoms of sensor or interference problems. If you reverse the sensors it should move one engine to wot and close the other. Problems tend to fall into the following categories:
- No Sync
- Hunting or oscillation
- erratic throttle servo movement.
Please describe what you are seeing now. Clearances are fine. Any less than 0.2" should work.
If you have 1.4Volts at the plug you have a bad plug if it is not hot.
Bill
