Pull-Pull Wire Connection? Crimps?
Hi Folks,
When you buy a pull pull system you seem to get plently of wire but only a few of the metal things you crimp to secure the wire to the connector. What can I use to crimp to hold the wire to the connector. I was thinking copper fuel tubing but I assume the copper is too soft and would not hold the wire tight with time?
Any suggestions?
Scott
