RCU Forums - View Single Post - Using covering material as hinges??
Old 09-18-2006 | 07:37 PM
da Rock
Default RE: Using covering material as hinges??
OK, here's the picture.
Each gap is where two pieces work together. They work to keep the aileron from slipping up or down behind the center of the trailing edge of the wing. Enough of them will insure that the aileron stays where it should when the aileron is buffeted by the airflow, and especially when it's deflected.
