Tailwheel
Instead of the wheel collars on the smaller 40-60 sized tailwheels, I usually solder small washers to the wire in the neccessary places (each side of the wheel, above and below the bracket, etc). Use a piece of a business card to keep the heat away from the tailwheel or plastic parts. If you have to remove it, just heat it up again.
