RCU Forums - View Single Post - Field Box Schematic Needed
Old 09-24-2006 | 11:12 AM
carrellh's Avatar
carrellh
Default RE: Field Box Schematic Needed
ORIGINAL: mouthpiec
i am looking for plans to built a field box.
The one you gave me are good but i wish the the box, on the top part will have 2 semi circles parts so that i will be able to put the plane on them
thanks
I have a box similar to the Hobbico model referenced in the Tower Hobbies link. I took a few photos of the cradle. You could make the parts from plywood, or other material, and adapt them to any box that has a similar design. The end parts of the box need to go about 2 inches above the handle and a vertical slot is cut for the screw that holds the cradle and box together.
ID:	529492   Click image for larger version
ID:	529493   Click image for larger version
ID:	529494   Click image for larger version
