Programming 9CA
Well what you are describing is definitely the complicated way to do it. Otherwise you can just control your flaps with one of the sliders or knobs, or assign the flap function to switch H. The method we went through will give you the ability to make fine adjustments in the air while still using a switch to activate the flaps.
