RCU Forums - View Single Post - Trimming a new plane!
Old 09-27-2006 | 03:37 AM
alan0899
Default RE: Trimming a new plane!
G'day Mate,
Check your rudder, on the ground, it should be in a straight line with you fin, adjust to make it so, then when in the air, trim your ailerons for straight flight, at around 1/2 throttle, if this trim changes as you change speed, either faster or slower, then you may have a warp in your wings. Also if your trim changes as you slow down, or speed up & you have checked your wings & found no warps, you may have a heavy wing on one side, check this as well.
But the best way is to get an experienced flyer to help with your trim, not necessarily trim it for you, but advise you as you trim.
