RE: GWESC35 amp problem
I am flying it with 4 servo on a 25e Su31 of Hyperion, no problem so fare, I’m using JR DS281 x 2 on the wing and 2x Jr DS3421 for the ruder and elevator, i really don't see why any one will say it can only support 2 servos? it's rated at 3 Amp, unless you have some really bad servo or if the installation has not been done properly so the servo is jamming and draining more current then normal, or else I can not see why you can not use up to 4 servo.
By the way, I’m using 3 cell lipo, if you are using 4 cell may be then the 2 servo saying is true as the BEC will be generating more heat due to the higher volt input to the BEC circuit.
