RE: Latex Coverage
I use behr latex and find yellows and reds do not cover well. A base coat of white may help; be carefull of the weight buildup as white is the heaviest paint, black is the lightest. You might try a white base on just the yellow parts. Ceck the colors outside if you paint under flourescent lights.
Good luck.
