Kavan Wingo
$89.00
Home Page:
http://www.hobby-lobby.com/hlwingo.htm
Videos:
http://www.hobby-lobby.com/media/HLF...WingoCombo.wmv
Reviews:
http://www.modelairplanenews.com/reviews/wingo.asp
Specifications:
Wingspan: 43.3 in.
Wing area: 403 sq. in.
Weight: 20 oz.
Wing loading: 7.2 oz./sq. ft.
Motor: 7.2V Speed 400 with direct drive
Prop: 4.92x4.33
Battery/ESC used: 8-500mAh AR Ni-Cd cells/Jeti JES 10 Acro
Radio: Hitec Focus 3
Another nice 3Ch Trainer. Rudder/Elevator Control. The Wingo builds in about
2 - 3 hours. This plane flies so nice and true. Glides forever. The stock wingo
comes direct drive with a Zagi Prop. This combo is ok but if you really want some
power and a higher rate of climb, i would suggest you get the Gearbox & Prop combo!
The only fault i have seen with the wingo is in anything other than a perfect landing
the nose will brake! Expoxy will fix it, but it will start to look ugly really fast!
