ORIGINAL: Dr1Driver
Any flutter? How much and what type of CA did you use? You didn't double the hinges, did you?
Dr.1
No flutter that I'm aware of, however this is only the 3rd time I'm flying this plane. No, I'm sure I haven't doubled the hinged. I used Zap CA and applied 5-6 drops of CA to each side as I belive the instructions said.
There's no slop in the linkages, but is it possible that a standard servo is not strong enough for this size rudder?
-tychoc
