RE: How to Test Ignition Cut-off on Magneto Engine
Hmmm, take a multi meter or if all else fails, a 9 volt battery w a test light will tell you when the switch is open and when its going to ground to shut off the engine, you don't need to crank over the engine, you just need to know which way the switch is open ( the run position) or closed ( the off position)
