RCU Forums - View Single Post - Return of Lunchbox..
Old 10-05-2006, 02:41 PM
  #256
jplmk
Default RE: Return of Lunchbox..
ORIGINAL: Lunchboxer
I have no idea which servo saver you ordered.. I run the Kimbrough unit on mine... yes, the kit comes w/ one, but generally they are a little bit too loose for my liking.. so when I run a metal gear servo, I always change the servo saver to some super stiff one (since the metal gear can take the stress) and that helps the steering a bit!!
It's the Tamiya's own (the bag with "Spare Parts" text on the photo) - I guess it might an improvement, as it comes with two options for stiffness, will try it out anyhow, to see if it makes any difference (will run Futaba's S3050 on it, so it should be handle the stress easily).
