ORIGINAL: broncojd
you need a 3rd set of shocks? are you adding a 3rd shock in the rear?
The short (yellow) ones (well, one of them) is for the 3rd shock mod (if I ever get my hands on to a couple of extra c-brackets), but I guess you could run them in different lengths (shorts in the front, naturally - might look quite neat). I will have 85 mm all the round, the yellows are 67 mm. Shocks are alloy oils, and from a shop called Conrad Electronics (in Germany).
