ORIGINAL: rlipsett
I would not recommend a 6 channel radio. I outgrew mine at about the 4th airplane when I started to get into 3d flying. The 6 channel did not have enough of the features I needed for flying. Features I am refering too are dual rates for elevator rudder and aielerons. 6 channel futaba's only have it for 2 channels. Also If you use split elevators with separate servos then the 9c can mix the two channels together and link the trims whereas the 6 and 7 channels can not. I would suggest buying the 4 channel beginner radio until you determine if you are going to like the hobby but the most basic computer radio I would recommend if you intend to fly anything more advanced then a 4 channel aircraft that is strictly pattern would be a 9c because it seems to be able to handle just about everything thrown at it and at 400 dollars it is reasonable compared to a 1000 9z. Jr has some comparable radios but I am unfamiliar with there models and capabilities but the are comparable
Exactly why I recommend the JR 6 channel radio. The 6102 has 4 programable mixes, and you can mix both elevator servos and aileron servos on the same model if you want. It's pleanty of radio for all but gian scale models requiring multiple servos for every control surface.
