RE: Painting over Covering ???
Campbec has described the procedure.
I suggest using the green "scrubbies" for abrading the film. All you want is a "frosted" appearance. Be careful as it is easy to go through the covering, especially on high points such as ribs.
I also suggest cleaning the area TWICE using rubbing alcohol and clean cloths to insure all the residue and oils are removed prior to masking, priming and painting.
