RE: E-Flite Mini Pulse XT Owner's Club
I have it pretty much done now. Just working on placing the ESC and receiver. I did run into a couple of things and thought I would share. The tailwheel does not come with the 1/16" collar that is required to attach it to the rudder assembly. The parts list for the cowl installation list (4) 2mmx8mm wood screws, but in the actual instruction it says use 2mmx8mm sheet metal screws. You use the wood screws obviously. The little sheet metal screws are actually for the servo control rods. Otherwise, the whole things was not too bad. The cowl is the toughest part. Really take your time I nearly missed the tabs on the fuse with the drill, luckily i just barely went into the fuse, so I could redo it. I will get some pics up later.
