RCU Forums - View Single Post - BVM 91
Thread: BVM 91
Old 10-17-2006 | 07:24 PM
Chris True
My Feedback: (14)
Default RE: BVM 91
You're right, I'm confused.
I've used the BVM pipe on the OS but of course when I fitted the JMP pipe the header needed to be changed to the JMP part. It MIGHT work if you used the JMP rubber piece over the BVM stub header since the pipe ID's are the same but it might not without the JMP ledge on the end of the header which protects the end of the seal somewhat from hot gasses...
