First, make sure the Tx is set for PPM mode (not PCM). Then read how to set the com port [link=http://www.clearviewrc.com/cvdocs/ClearViewDocTOC.htm]here[/link]
After the Tx is on and cable plugged, start ClearView, select "Settings" then "Controller Setup" and select the com port and assign the channels.
Stefan
http://rcflightsim.com
