RE: thinning epoxy
Just say no to thinning epoxy.
Warm the stuff up to make it flow. If you are doing a glass tape wrap of a dihedral break, use a heat gun to heat the epoxy and a credit card to work it into the cloth. If you are glassing a wing, fuselage, etc., then use a finishing resin (or laminating resin) as has been suggested.
