RCU Forums - View Single Post - Razzle 3D
Thread: Razzle 3D
Old 01-18-2003 | 12:04 AM
jetranger-RCU
Default kit
I just put one together. I would not by another--Hinges are pinned and not glued on my kit wood soft white balsa ---very little glue on wood joints poped cross braces out by holding fuse. The wing hold down block and wing bolt angle not lined up both facing forward had to break off and realine. Slot for hinge 1/8 by 1/2 they use a Dubro like hinge just floats around in slot. Some of the pins do not go through the hinge they have no point on them. Bolts for wing sloppy fit in tee nuts. tee nuts are plastic hardware they give is the worst I've ever seen. Read some of the other threads on Seaqull models to see other problems
