RCU Forums - View Single Post - depron and bluecor???
Old 10-24-2006 | 05:56 PM
jdetray's Avatar
jdetray
Default RE: depron and bluecor???
Without seeing the Bluelinx product, I don't know if it the same as BlueCor or not, but the basic specs are the same. Real BlueCor has a thin plastic film on both sides that adds much strength.
BlueCor is a bit more flexible and less brittle than Depron. Depron is flatter and more uniform than BlueCor, which often has slight ripples or waves in it (which you can see in the photos below). But BlueCor is much, much cheaper!
BlueCor is a Dow product intended as home insulation:
http://www.dow.com/PublishedLiteratu...1380484d94.pdf
- Jeff
ID:	547373   Click image for larger version
