RE: A123Racing Battery Questions
For A123/Brian
In answer to my inquiry as to how to connect the cells in series in your Four Cell Developer Kit, HS-DK-4, which have only one tab, according to the website, you said:
"...the loose cells that we offer have a small nickel tab as you mentioned. Soldering to the end of the nickel tab keeps the intense heat far enough away from the cell to ensure that it is not damaged."
I understand that with regard to cells that have two tabs.
But my question was / is, how do I connect the cells in series if they have only one tab as stated in the website for the Four Cell Developer Kit, HS-DK-4?
Do those cells in fact have two tabs, or only one tab as stated in the website?
If they have only one tab as stated, how do I connect them in series since soldering is forbidden?
Bob
