RCU Forums - View Single Post - Nylon Wing Bolts
Old 01-19-2003 | 07:26 PM
jettstarblue's Avatar
jettstarblue
Default Nylon Wing Bolts
Ah, Lowe's, my SECOND hobby shop.
Did you get the nylon bolts at Lowe's? They have several sizes. The steel bolts will work, but they won't break like the nylon ones.
Just a note, if you break them, and can't get them out, use a hacksaw blade, or dremel, and make a new "slot". If it's broken off inside, and you can't do this, then heat up a screwdriver, and make a new slot,- carefully,let it cool, then use a screwdriver to remove.
Jetts
