RCU Forums - View Single Post - Panel Line Problem
Old 10-26-2006 | 09:18 PM
mark IX
My Feedback: (9)
Default Panel Line Problem
Ok you guys, I don't know why this is'nt working.[&o] I am using 1/64 wide tape to create panel lines on a scrap piece of glassed balsa sheeting. I picked this width to use on my BT Spitfire 83" kit figuring that width is about right for the scale size of the model. I marked out some lines on the primed piece of scrap balsa and applied the tape over the pencil lines. Then I sprayed over only the tape with three coats of latex primer, letting it dry in between coats. After the third coat dried, I removed the tape. The tape was difficult to remove, but I eventually got it all off. The taper came off in pieces instead of one continuos length[:@]. Maybe I should have removed it before the last coat dried.
My question is, it looks as though the panel lines are not deep enough. They are barely visible in some spots. Am I using tape that is not thick enough? Do I need to apply more than 3 coats before removing the tape? Is there something I'm missing here or is the way it's suppose to appear. I am worried that after applying the color coats the panel lines will be filled in.
Mark
