RCU Forums - View Single Post - Panel Line Problem
Old 10-27-2006 | 09:18 PM
gsmith6879
My Feedback: (37)
Default RE: Panel Line Problem
You should sand the primer down to the top of the tape and then pull it up. I found that a light application of heat from a heat gun helps release the tape. I then soak the groove with Goo Gone to disolve the tape residue left in the crack and clean it with a QTip. Clean the Goo Gone with rubbing alcohol to get rid of the oily residue.
