RE: KAOS AND RELATED PLANES AND INFO
I remember the spars, LE, amd TE being notched. Below is a scan of the Super Kaos plans clearly showing a 45 degree LE. Be aware that this is NOT a cross-section thru a rib but rather a section thru the wing at the fuse side, thus no reason to show the hidden notch and flat face on the rib itself. Kapesh?
Late addition..reading the construction article it does mention gluing on the notched spars, LE, and notched TE.
WiNG:
The RCM \~ing Jig is highly recommended to assemble the wing. (See the August 1967 issue of R/C Modeler Magazine Xerox copies of article available.) Using 1/4” steel rods in the holes in the ribs, this jig can give you a true wing in much less time and work than usual construction methods. If you do not use the RCM Wing Jig, use a flat building board and make up small jig blocks. Pin the blocks to the position shown on the plans. Glue the ribs to the spar with the landing gear notch in ribs No. 2 and No. 3 down. Do not glue in the false ribs or the 1/4” dowel. Glue the top spar into position. Glue the notched trailing edge to the ribs and pin to the jig blocks. Glue the notched leading edge to the ribs, let the glue dry before proceeding, then glue the front and rear sheeting in place (the leading edge of the front sheeting is tapered). It is recommended that the forward sheeting be dampened with water Ofl the outside surface only. This will cause the sheeting to curl and conform to the rib
Hope this helps.
Dave Rigotti
