RE: COX Micro Warbird ARFs
Ok, thanks. I haven't run it at full throttle yet so I'll check for vibration then.
I decided to simplify the tail linkage by only using the long wires with "Z" bends in one end for the servo arms. After gluing the stabilizers on with a small amount of epoxy, I cut the wires to length and put an "L" bend in the end for the control horn. A small piece of insulation from the charging cable works perfect to help secure the wire onto the control horn.
The pre-painted canopy was attached with UHU POR.
