RE: TF P-40 Build Thread
That Saito should work out just fine. You are going to need to do something with your tank placement. a Cline or Iron Bay regulator may not be a bad idea due to the fact that you may not be able to get the tank low enough. I'm Getting an OS .91 Surpass for mine because OS makes all the exhaust plumbing you need. I'm also going with the OS aluminum mount as well. I will be going with a 12 oz tank mounted through the firewall and centered on the carb with fuel lines looped above to prevent syphoning.
