RE: beechcraft stagger wing
Race66 the staggerwing you are referring to is the .60 size in Dec'75 issue. I'm looking to build a .60 size staggerwing myself. The Ray Dehn plans in RCM (pl-620) call for foam core wings and are 25.00 usd. The Ziroli plans are about 50 bucks and would need to be scaled down. I have yet to look at any other plans. I would like as much info as I can get before I get started. I'd like to find a set of Royal plans, I hear they are good and much cheaper than Ziroli. I'd just go for the Ray Dehn plans except I'd have to convert to built up wings instead of foam wich I could do but seems like alot of trouble. If I go Ziroli or Royal the plans need to be scaled...either way I guess the plans would need modification for size or wing construction. Any info you guys have would be appreciated.
