RE: problems taking off with training gear
For training the wood flat bottom blades are better because of the weight. Keep it in normal mode, put your throttle trim to just under half way up. Pitch should be about 3-5 degrees positive with throttle in full down. Heli should lift off at about 60 percent throttle. If this doesn't happen, I might recommend upgrading your battery to a TP1320.
