RE: Easy way to set thrust angles?
Thank you for the responses. I haven't been online for a while so I apologize if there has been a delay.
The disc idea is fantastic... beats me spinning the prop around eleventy million billion times trying to get measurments.
Once I get the little guy up in the air (and then again when the air it finds itself "up" in cooperates) I'll use your little guide critterhunter.... I've flown planes with no thrust angle so it shouldn't be disasterous like Matt had mentioned... Now just to get in gear and finish this thing up before the snow starts falling.
Thanks again,
Patrick
