RE: Hull Repair Help
Found a great product at my local Marine store Aquaepoxy. Basically you hand mix it into a thick dough and then simply push it into the damaged area. Is 100% designed for water and sets as hard as rock! You can then sand it, drill it paint etc etc. Apparently it will even set if you needed to do a repair while the hull is wet although I wouldn't recommend it.
