RE: 26 inch mono build thread
I would use some good hardware on it fullers makes a nice kit also. If you want to save a few bucks you could make your own engine mounts. Check out my thread I used some aluminum angle stock just make sure its thick enough so it dont flex. Save you thirtyfive bucks or so. You can probably find at Lowes or Home Depot in the hadware Isle theres usually a steel rack. The only thing is you will get more vibration. But you can wrap reciever in foam rubber to take care of the vibe. Hitec makes a nice vibe matt for there recievers. Dave
