Blade CP and Eclipse 7 settings
I have tried to search for settings to program my Eclipse 7 radio with a Blade CP. I can get everything to function, but the fine points are less than desired. The CP works fine with the stock controller, but with the Eclipse it will jump off the ground. Anyone using the same radio? If so, would you share your settings? I disconnected the main and tail motor and tried to duplicate the stock radio for throws, but it still jumps. Also, I have very little heli experience and this is a first at programming a radio in Heli mode. Any input is greatly appreciated.
